SpotlightCreating hoist reports
Command
Path
Create Hoist Report
Spotlight > Reports
The Create Hoist Report command generates detailed lists of hoist data and measurements. The hoist report can be customized to list the hoist ID, name, capacity, position (the X,Y coordinates of each hoist relative to the origin and the trim height, using the document units), reaction force, and/or origin name. In the Create Hoist Report dialog box, select the sorting method that is best suited for the hoist layout. A preview illustrates how the sorting method is applied. The hoist report can be exported as a .csv or .pdf file, or as a Vectorworks worksheet (see Concept: Worksheet overview).
The hoist report is optimized for riggers. To create a pre-defined database worksheet instead, see Creating reports.
To create a hoist report:
Select the command.
The Create Hoist Report dialog box opens.
Parameter
Description
Reference Point
Select the reference point for the hoist measurements.
For a custom origin, select Hoist origin. Select <Object Origin> to use the hoist object origin, or select a hoist origin that was created with the Hoist Origin tool.
Sorting Method
Select the method for ordering hoists
Hoist ID
Sorts the hoists by Hoist ID
Y position
Sorts the hoists by their Y coordinate position. The hoists are sorted into columns by their Y position, and then sorted into rows by their X position.
Ant system path
Best for irregular layouts, this option sorts the hoists by their sequence on an “ant-like” path. The algorithm finds a short, direct path connecting the hoists.
Straight path
Best for regular layouts, this option sorts the hoists by their sequence on a linear path. The algorithm finds a short, straight path connecting the hoists.
Format
Select the format for export
Preview
Illustrates how hoists are ordered by each Sorting Method
Optional Exported Fields
Select the fields to include in the report; Braceworks is required to export reaction force
Specify the hoist report parameters.
Concept: Braceworks structural analysis
Placing hoist origins
Placing hoists
Workflow: Hoists
